Battery Drain
Old May 6, 2016 | 07:21 PM
joescvette's Avatar
joescvette
Default Battery Drain
1978 has a battery drain on the courtesy fuse line. Pull the fuse o reading, replace fuse, I get 12.9 reading, on the neg cable side. everything off. I took off the neg. cable and put a multimeter dc volts between. Is something wrong?
Old May 6, 2016 | 07:37 PM
Giant_Robot's Avatar
Giant_Robot
Explaining your problem in English might help.
Old May 6, 2016 | 07:45 PM
joescvette's Avatar
joescvette
In the fuse box the interior light fuse, has a drain. Take fuse out no drain. Replace fuse I get a 12.9 reading on my multimeter.
Old May 6, 2016 | 07:47 PM
Giant_Robot
Is the door open, or are you in the car with the door closed at this point?
door open = interior lights on.
Old May 6, 2016 | 07:50 PM
joescvette's Avatar
joescvette
Door open interior lights off. Everything is off.
Old May 6, 2016 | 07:51 PM
Giant_Robot
If your courtesy timer delay is anything like mine was.. it will be hot to the touch. Its located under the dash in the middle, might want to touch that.. then remove it, and splice your lines together to get the lights to turn off, just there will be no delay. possible the drain is there?..
Old May 6, 2016 | 07:53 PM
Giant_Robot
if the door is open you are opening a circuit to turn on the lights.. close the door. You cant really test a drain with the door open. Do your interior lights even work?
Old May 6, 2016 | 07:58 PM
joescvette's Avatar
joescvette
When I replace the fuse everything works normal. The timer works fine. Everything in the car works. My charger keeps charging with fuse in. With fuse out it doesn't.
Old May 6, 2016 | 08:01 PM
Spoticus's Avatar
Spoticus
My 78 had a current drain on the courtesy fuse line as well.
Main culprit was the security relay for the original security system (170mAmp). The relay is located down near the shifter in the centre console. Do you hear a relay click in that location when you plug the courtesy fuse back in?
I just unplugged the relay and left it there as I have a after market security system installed.
Other drains on that circuit were the after market security system (20mAmp) and CD Radio memory (1mAmp).
If the doors are open and all the interior courtesy lights are on the current drain was around 2 Amps.
Old May 6, 2016 | 08:06 PM
joescvette's Avatar
joescvette
The org. security system works. Could that still be the problem?
Old May 7, 2016 | 01:05 PM
69L46's Avatar
69L46
2015 C3 of Year Finalist
St. Jude Donor '15-'16-'17-'18-‘19-'20-'21-'22-'23
I would suggest locating a wiring schematic for your car and seeing what else might be involved. Using a non-contact voltage tester might make it a bit easier to isolate at what point the current stops flowing if you try to remove components.
Old May 7, 2016 | 05:25 PM
joescvette's Avatar
joescvette
Thanks I will try every ones suggestions.
To Battery Drain
