Corvette Engine Numbers and Trans
Old May 12, 2016 | 04:01 PM
gwraalstad's Avatar
gwraalstad
2nd Gear
Default Corvette Engine Numbers and Trans
Ok, I finally got all the numbers off the engine I could: What do I have. My research tells me that it is a 1975 350 165 HP.
Front Pass side - V0827CHB 2JL218244 (Alt # 2A218244)
Casting # GM 5.0LG
I think the Trans is a TH700R4:
MD8 on the side
8FAM067C 8642547-2
Old May 12, 2016 | 09:03 PM
'75's Avatar
'75
The engine block may or may not be from a 75 corvette, but the top end and front accessories are certainly not.
Old May 12, 2016 | 09:51 PM
mjfrank's Avatar
mjfrank
I believe the "CHB" stamping indicates a 1988 305cid 190hp engine used in a Pontiac Firebird. The casting of "GM 5.0LG" I think confirms a 5.0 liter (305cid) From the look of the valve covers, the heads appear to be vortec heads.
Old May 13, 2016 | 12:03 PM
BBCorv70's Avatar
BBCorv70
Looks a lot like the 305 with fuel injection I had in my 1987 Firebird... Top end is mid 80's or newer...
To Corvette Engine Numbers and Trans
