fuel pump
Old May 15, 2016 | 01:28 AM
llabesab7's Avatar
llabesab7
Default fuel pump
i have an 82 collectors edition. I heard these cars will perform better with a fuel pump change with a pump thats on an 85 thru 87 vette. Is that true and if so would that be an ac delco. thanks
Old May 15, 2016 | 08:05 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
pumping more fuel into a engine that can't burn it any faster will do more harm then good
Old May 15, 2016 | 11:59 AM
terry82's Avatar
terry82
the change over to a 85 to 89 fuel pump is one of the best upgrades you can do.The 82 pump does not keep up very well.also open up your cat or change it .These do upgrades are the most common on a 82.you also might need to look at this https://www.corvetteforum.com/forums...solutions.html
Old May 15, 2016 | 03:02 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
YES! I changed mine out and it made all the difference in the world.
Also, (although counter intuitive) make sure your emissions stuff is up to par. I made sure all mine was working, in conjunction with the new fuel pump and the CFI works very well.
Old May 15, 2016 | 05:11 PM
llabesab7's Avatar
llabesab7
Default fuel pump
what changes should I see and what do you mean about the emissions being up to par. Thanks
Old May 15, 2016 | 06:59 PM
fishslayer143's Avatar
fishslayer143
It is an improvement but your engine still has to breathe thru an intake that was first designed for a 305 CI engine .. It won t be dramatic
Old Jun 2, 2016 | 10:07 AM
llabesab7's Avatar
llabesab7
Default fuel pump
I had my fuel pump changed on my 82 collector like we discussed. It made a noticeable difference on the performance. I'm very pleased. Thanks for the feedback
Old Jun 2, 2016 | 10:08 AM
llabesab7's Avatar
llabesab7
Had a new sending unit put in also
Old Jun 2, 2016 | 04:00 PM
terry82's Avatar
terry82
To fuel pump
