Remove seats from 81 Corvette?
Old May 16, 2016 | 01:12 PM
Paul Workman's Avatar
Paul Workman
Default Remove seats from 81 Corvette?
How do I remove the seats from an 81 Corvette?
Old May 16, 2016 | 01:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Remove the four track mounting bolts from each seat. Two in the rear and two in the front.
Old May 16, 2016 | 03:05 PM
kdlp's Avatar
kdlp
Yep, and if you have a power driver's seat remember to unplug the harness.
kdlp
Old May 16, 2016 | 03:20 PM
Reaper19's Avatar
Reaper19
Just did this not to long ago in my 81. On the passenger side, slide the seat all the way back to remove the two front bolts from inside the passenger compartment. Then slide the seat all the way forward to remove the rear.
On the driver side, if electric seat, remove the nuts from the bottom of the seat and as mentioned don't forget to unplug the wiring harness for electric motor and seat belt.
Here is a few pictures and removal procedures:
http://www.autozone.com/repairguides...00c152800838f1
Randy
To Remove seats from 81 Corvette?
