idler belt
Old May 18, 2016 | 10:35 PM
Omarsvette's Avatar
Omarsvette
Default idler belt
i need help finding the belt for the idler pulley. I'm having a really hard time. a 32 5/8 is too small and 33 1/8 is too big. zip says they have it but its 31inches. auto parts store don't have anything in the middle.any help
73 ls4 with a/c
Old May 19, 2016 | 09:39 AM
71 Green 454's Avatar
71 Green 454
73 ls4 with a/c
I use a Gates 7320 on my '71 LS5, 3/8" x 32 5/8". You might find it too short, but you have to remove the top pulley, then put the belt on the crank pulley first, then put it on the top pulley and re-install it on the water pump studs. I've been doing it this way for over 40 years.
If you use a belt that fits without removing the water pump pulley, it will be too long.
Old May 19, 2016 | 10:06 AM
Omarsvette's Avatar
Omarsvette
yeah i was thinking that last night after reading more. i tried that 7320 but even with the pulley of, it was impossible. but i had the studs on. so I'm going to get that belt again and try it. and remove the studs.
Old May 19, 2016 | 10:27 AM
71 Green 454
Good luck.
Also, I made note of 2 other forum members belts sizes for the crank to water pump belt. I still prefer to use Gates brand.
One used Goodyear 15325 and the other used Dayco 15440.
Old May 19, 2016 | 11:26 AM
Doug Kraft's Avatar
Doug Kraft
You could try a place called poly tech designs out of NJ. They usually can make any length belt you need. They make them for my belt drive system.
Old May 19, 2016 | 03:34 PM
Mooser's Avatar
Mooser
Deleted
Last edited by Mooser; May 19, 2016 at 03:36 PM. Reason: Thought it was the crank - water pump belt he needed
Old May 20, 2016 | 10:19 PM
Omarsvette's Avatar
Omarsvette
gates 7320 works perfect. removing the water pump studs is a must.
To idler belt
