1981 Trim Tag help
Old May 23, 2016 | 03:17 PM
Doug Harden's Avatar
Doug Harden
Default 1981 Trim Tag help
Hey Guys n Gals,
I've been asked to help document a 2 owner, 1981 T-Top coupe, with extremely low miles, as in under 2,700 actual miles.
The car definitely looks like an honest car, but I have a couple questions.
The car was one of the last built in St. Louis, (K30) (VIN checks out too).
The curiosity is that the Trim Tag was painted over, body color. So much so, that it's hard to read. There are NO other indications that the car was in any sort of accident, etc...or resprayed.
My assumption therefore, is that either this was 'normal' for St. Louis cars, or due to the fact that it's within the last 2k built there, they just didn't give a dang.
Anyone else have a St. Louis car with a painted trim tag?
Thanks again,
Doug Harden
Old May 23, 2016 | 04:01 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If memory serves, possibly by the 77 model year, trim tags were being attached in the paint shop between color coats.
Old May 23, 2016 | 04:40 PM
Doug Harden
This is the tag in question. Appears to be some paint flacking by the rivet, probably due to a bubble or dirt during painting.
Old May 23, 2016 | 04:52 PM
gbvette62's Avatar
gbvette62
That tag looks right to me. Red exterior and black leather interior, with a body build date of June 30th.
The trim tag was attached to 81's at St. Louis, between the second and third color coat. At Bowling Green, the tag was installed after the body left the paint shop.
81's built in St. Louis should have painted trim tags, while BG cars have unpainted tags.
Old May 23, 2016 | 04:58 PM
Doug Harden
Thanks guys!!
Old May 24, 2016 | 04:49 AM
hunt4cleanair's Avatar
hunt4cleanair
Doug
As GB and Easy note above, 81s were shipped with paint on the trim tag. This practice was consistent from 1977 through the end of St Louis production. The practice began somewhere in 1975/76 when the booth was moved to accommodate the increased number of Corvettes being built to a location between the first and second color coats.
Thus, the trim tag was not present when the primer coats were sprayed and typically paint will flake off the trim tag. Now having said that, the paint looks heavy on the tag but nothing I would question.
This is a good issue that deserves clarification as you document the 81 for a friend. Also consider the build sheet that will document broadcast codes on the mechanical parts such as alternator, starter, carb, suspension, etc. In a low-mileage Corvette it may be just laying around like under carpet, in one of the rear storage compartments (under jack), etc. The standard practice was to glue it to the top of the gas tank but that tends to be a challenge to retrieve. Better to confirm its there and leave it alone...noting it is there.
Hope this helps!
Old May 24, 2016 | 05:57 PM
sullyman56's Avatar
sullyman56
My 77 has no paint at all on the trim tag. The build date for mine is September 1, 1976 so could it be the practice you describe began later?
To 1981 Trim Tag help
