C3 seat swap
Old May 24, 2016 | 02:05 AM
TheGreek!'s Avatar
TheGreek!
Default C3 seat swap
The seats in my 69 are raggedy and need to be restored. Even if they were restored they still look kind of bland and they aren't very comfortable. I want to do a seat upgrade in it. I like the looks of the 84-93 C4 seats, would they fit in a 69? The seat bottoms can't be more than 20 inches wide in order to fit between the center console and the door and I want them to be able to fold forward so that I can access the storage compartment behind the seats. I'm open to trying seats from other cars too if the seat looks sporty/comfortable enough and can be easily adapted to fit the seat tracks of the 69. Any suggestions??
Old May 24, 2016 | 02:50 AM
Lobzila's Avatar
Lobzila
There have been a bunch of posts on this subject lately. I went with a set of C5 seasts in my C3. If you run a search you will come up with all kinds of ideas from this board. Good luck.
Old May 24, 2016 | 03:03 AM
Sunstroked's Avatar
Sunstroked
Those look nice lobzila.
Old May 24, 2016 | 03:09 AM
Sunstroked's Avatar
Sunstroked
I talked with a rep from recaro at the B-J auction recently. He told me no seats that they make will fit in a C 3. Hmm, maybe thats a corporate response, you know, lawyers and all.
Old May 24, 2016 | 09:05 AM
74Ken's Avatar
74Ken
Search and you will see loads of posts on Seat options.
I went with 84 Fiero seats in my 74.
Originals were like sitting on a board with foam stuck on it.
Ken
Old May 24, 2016 | 03:54 PM
Haggisbash's Avatar
Haggisbash
I am in the process of adapting C4 seats into my '70 and by the looks of things they will fit okay but sit higher than the originals if using the C4 seat tracks. So far it I have measured up and found the front mounting holes of the C3 seat tracks will line up with the C4 seat holes but I will need to make adapter plates to reach from the rear seat holes to the tracks ( I am making everything so that it can be returned to stock if required). Using the C3 tracks seems to be the way to go but means ditching the electric adjustments so sourcing manual C4 seats will maybe save some $$.
I have seen mention that the C4 seats rub on the door panels but so far this doesn't appear that it will be the case for me. I have a thread running in the tech section where I am documenting the change if you are interested.
Old May 24, 2016 | 07:05 PM
ignatz's Avatar
ignatz
au contraire, mon ami
https://www.corvetteforum.com/forums...ere-s-how.html
However, if you or your passenger have an ample derriere, these are not the seats for you!
Old May 24, 2016 | 07:58 PM
TheGreek!'s Avatar
TheGreek!
Thanks for the replies guys, every bit of info helps. My search fu isn't very good, I can't seem to find any other threads on seat options for a C3 other than the thread from haggisbash and the one that ignatz linked to. If anyone has some more links to other C3 seat threads it would be greatly appreciated.
Old May 24, 2016 | 08:53 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Heres one
https://www.corvetteforum.com/forums...re-aweful.html
Theres no available fiero seats in my area, so I picked up.some c5s for $300 that need some work, new seat bottom foam and a 1 inch tear to be sewn. Can't wait for some free time
Old May 24, 2016 | 11:44 PM
Doug Kraft's Avatar
Doug Kraft
Corbeau A4 narrow version with the 1" shaved foam option is what I put in my 76. Granted they are a bit much and with the sliders mounted they couldn't tilt forward but since I'm the only one that drives it mounting them straight to the floor as far back as I could get them was no problem.
Old May 26, 2016 | 10:09 AM
Snoopysvet's Avatar
Snoopysvet
Recaros out of an old BMW, they bolted right in
[/QUOTE]
Old May 26, 2016 | 10:15 AM
Snoopysvet's Avatar
Snoopysvet
[/QUOTE]
Old Sep 8, 2016 | 08:39 PM
VETFEVER's Avatar
VETFEVER
seat bump
vetfever
Old Sep 8, 2016 | 11:20 PM
Richard454's Avatar
Richard454
I like 'Snoopysvet' Recaros- and I actually have a set of them in my 78' E21 BMW- Might have to try them out.
My original plan was the Corbeau GTS II-
I'm 5' 11" and feel like I'm sitting up a little too much- so will try taking out some of the foam .
These things are tight- my interior is custom and think a stock interior would be an even tighter fit.
I had the headrest cut down- because I felt they looked to tall and had more of a 69 seat headrest look.
Now I am look at maybe going w/ something else- Porsche seats seem to be small enough-
914 seats- and i found it sort of funny that this guys shop does Porsches- has a picture of the seat in front of a C3
here's another seat for a 911 that looks like it'd be a good fit-
I think these are a good balance between track and street
Old Sep 9, 2016 | 12:41 AM
Mike414's Avatar
Mike414
5th Gear
Fiero seats with a Mr. Mike's upholstery kit in my 73.
Old Sep 9, 2016 | 09:12 AM
Rescue Rogers
Who did your sear covers. Thats exactly the color and pattern I want for my c5 standad seats. Thanks
Old Dec 1, 2020 | 12:15 AM
CHRISTOPHER PRIZGINT's Avatar
How are those seats holding up? Does the leather hold up well? In some pics the leather looks cheap. Yours came out awesome.
Old Dec 1, 2020 | 09:30 AM
74Ken's Avatar
74Ken
Mine look as good as the day I put them on.
Remember, Leather seats need to be conditioned at least once a year or they will dry out and split/crack.
I just got some conditioning wipes to try out.
Mr Mike has at least two different blacks, so ask for a sample pack.
Old Dec 1, 2020 | 01:55 PM
vettebuyer6369's Avatar
vettebuyer6369
This member hasn’t logged in in 2 years. His post was 4 years ago. You could try a PM.
To C3 seat swap
