My '77 restoration: Update
Old Jun 4, 2016 | 10:23 AM
kruser's Avatar
kruser
Default My '77 restoration: Update
Well, had a vibration in the rear drive train, ended up rebuilding complete trailing arms, half axles, struts...didn't fix the issue. Finally nailed down the issue. I had put the u-joints in backwards, and the grease zerk hole (the raised part that it screws into on the ujoint housing" was hitting the pinion bold as the drive shaft turned. Very small bumping made a pretty big vibration. Lesson Learned!! Here is how the old girl turned out. Wonder what my next project will be.
