Ok, I was hooking up my new radio in my '68 and ran into a strange problem. I went -
Car Radio
Yellow - Yellow
Black - Black
Grey - Red
I hooked the battery back up, turned the ignition to ON and nothing. I checked the fuse and it was fine. On a whim, I put the red and yellow together and the lights behind the gauges lit up and the radio turned on - with the ignition turned off. I get that the ignition wire is not working to turn on the radio, but why did the gauge lights come on? Also, how to do fix the issue?
Thanks, guys
Ok, I misread and thought the yellow was the constant. Where did the original radio get constant power from?
The original radio didn't have a constant, just yellow power, black ground, and the grey for lights. There's a terminal labeled BAT on the fuse box you can get 12v constant from.
They didn't need a constant power source.. lol.. Unlike today's memeory radio's you only had switched voltage. If you need constant you can pick that up in the fuse panel.
