Torque Thrust II - NO 4" BACKSPACE OPTION!!
Old Jun 6, 2016 | 02:02 PM
Justin Braune's Avatar
Justin Braune
Default Torque Thrust II - NO 4" BACKSPACE OPTION!!
Its driving me crazy here searching for this so called phontom 4" backspacing.
Where is everyone getting these TTII's with a 4" backspace?
The factory doesn't make that backspack:
http://www.americanracing.com/wheelS...ust-ii-1-piece
VN5155863 15" x 8" 5x120.65 0 4.50 POLISHED 83.06 1580 lbs $191 3505293
VN5155861 15" x 8" 5x120.65 -18 3.79 POLISHED 83.06 1580 lbs $191 3505293
Old Jun 6, 2016 | 02:55 PM
MelWff's Avatar
MelWff
only if it's custom made which is very pricey
Old Jun 6, 2016 | 03:00 PM
Justin Braune
Default Best of two and main difference?
Awesome
SO what is the difference between the two, physically and looks/performance wise on the car and which is the better choice of the premade options?
Thanks,
Justin
Old Jun 6, 2016 | 03:14 PM
530planeman's Avatar
530planeman
I have a spacers 1,1/2"
Old Jun 6, 2016 | 03:21 PM
MelWff's Avatar
MelWff
You didnt state a year in your post or profile but I'm guessing you have a 68 to 72 bumper car and when you use their tools it tells you the BOLD number will fit your car. In this case it points to the VN5155861 with the 3.79 BS. They basically will perform and look the same other than a less than 3/4" difference in offset. The 3.79" is closer to the factory offset. Personally I went to the 17" wheel in order to have a much greater selection in performance tires.
Old Jun 6, 2016 | 03:34 PM
The Punisher's Avatar
The Punisher
Did you try wheelsforless.com. I bought mine from there 17" 4.07" backspace
Old Jun 6, 2016 | 04:25 PM
ddawson's Avatar
ddawson
https://www.corvetteforum.com/forums...post1592364761
Old Jun 6, 2016 | 05:56 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
The 3.79 backspace option would be barely noticeable.
Old Jun 7, 2016 | 01:51 AM
Justin Braune
Default Mr. Spacers
GOT IT! You have spacers... but WHAT SIZE RIM DO YOU HAVE?
Old Jun 7, 2016 | 01:54 AM
Justin Braune
Default Kibs
When you say "barely noticable", exactly what do you mean? My interpretation is that you are saying it is so close to 4" that its the same.
Also, which sticks out more, 4.5" backspace or 4" backspace?
THANKS!
Old Jun 7, 2016 | 02:26 AM
Rushfananatic's Avatar
Rushfananatic
6th Gear
THANKS!
If the wheel is the same width, a 4" backspace will stick out .5" MORE than the 4.5" B.S. wheel.
The 3.79" B.S. Wheel ( if same width) will stick out just under 1/4" lmore than the 4" wheel. If having inner fender well interference it Might allow you bump up from a 245/60 to a 255/60 15 for example. A 255 is about .4" wider than a 245 sidewall to sidewall
Old Jun 7, 2016 | 02:36 AM
Rushfananatic
6th Gear
I love raised white letters on our American muscle/ sports cars,
Which system do you use on yours? Do they stay on reasonably well?
They look great.
Old Jun 7, 2016 | 07:14 AM
Kubs's Avatar
Kubs
THANKS!
Yes 3.79" is almost exactly the same as 4.00" It is 0.21" or 5.33mm different meaning a 8" wide wheel will stick out 0.21" or 5.33mm farther than stock. You have to have a pretty good eye to notice that difference.
Old Jun 7, 2016 | 11:30 AM
ddawson's Avatar
ddawson
They look great.
I got them from these guys. http://tredwear.com/
They have not come off but I'm careful then cleaning them.
To Torque Thrust II - NO 4" BACKSPACE OPTION!!
