78.C3 A/C cac line-controls?
Last year I had my A/C system upgraded to the R134A..lso replaced the heater fan a/c switch in the console..Blower works fine and so does the heater.However..even tho the compressor is working fine and everything is ice cold on the engine side of the A/C..the system isn't closing the vents properly to transition from A/C and allow cold air to circulate into the car's cabin.Any suggestion about where to start?jim
Sounds like you may have disconnected the source vacuum hose, or the vacuum manifold could be leaking. The white stripe hose to the heater control may also be something to look at. The vacuum hoses are small, so almost any vacuum leak will kill the vacuum control of the control diaphragms.
The heater control valve gets vacuum in the max position, if there is a vacuum leak in that valve it will prevent control or slow the movement in all systems. Plug that hose,and see if anything changes.
So..if I am understanding your direction..disconnect & plug the vac hose from the inline heater hose control valve with the a/c in max setting and blower on full and see if anything changes?And if nothing changes..the vac solenoid control valve that's inline in the heater hose may be the culprit???? IF the heater works full blast..the control valve isn't openig-shutting as it's supposed in response to the control changes/Jim
Jim, on your 78 there should be a vacuum valve behind the glove box area that is controlled by the temperature cable. When the control **** is moved all the way to cold, the vacuum valve behind the glove box should send vacuum to the heater hose valve and cause it to shut off the hot coolant. That same temperature control cable moves a blend door inside the hvac box to direct more or less air through the heater core to change the air temp.
jim in oregon (06-07-2016)
Thanks..
Going to do a complete check on the vac lines from console component/switch( new and properly installed).AmaZING HOW MANY vacuum lines come off the heater/climate control switch-apparatus and how Few exit the firewall to go anywhere..The one from the heater control valve is the primary one I can readily see..
Not sure Chevy's Astroventilation system is great..but reckon it works after a fashion if I canferret out the problems..
Think the vacuum line that attaches to the vacuum connection behind the glove box is the culprit..
Have a new heater control valve just in case but it's not getting the vac that changes it's mode. Neither on lo or hi..No discernable vacuum at on the incoming vac line when controls are in proper mode at all that I can feel with wetted tongue anyhow..
That line runs thru bulkhead and I assume from there goes to the valve behind the glove box..Think I'll look behind the glove box first..and if I must remove the glove box..Think that's a more logical place to start rather than pulling the troublesome carpeted side panels off the console..Any other thots are certainly welcome.Jim
