difference between a q jet automatic and manual?
Jets? ect??
and can you interchange the two or modify one to use for the other?
I got a q jet for an automatic that I want to use on a 454 manual.
Much thanks and Happy Fourth of July!!!
Depending on application / maker, some other differences would be AT carb will sometimes have an extra vacuum port for the vacuum modulator and sometimes an idle compensator. It will also usually have extra linkage for the kick-down for the auto trans / passing gear.
Normally (only from my experience), re-jetting (if needed) is the only "real thing" that anyone normally does when using an AT carb on a manual trans car, so using it on your car normally wouldn't be a big deal.
In your case / the case of a Corvette owner, If you may be looking for a particular carb number - auto vs manual.....? I'm not sure at all of how they are actually numbered so I really can't help there.. but "functionally" , using it normally does not present a problem.
Have a great 4th !
