Panel Access
Old Jul 15, 2016 | 09:42 AM
blanman61's Avatar
blanman61
Default Panel Access
Newby owner. Had a 61 back in the 60's and have just bought a 78. Wanting to know how to remove the panel at the back of the cargo area where the speakers are mounted. Tried several searches but probably not using the correct terms.
Wanting to reconnect original speakers & eliminate the aftermarket ones currently connected. Thanks,
Old Jul 15, 2016 | 09:56 AM
KingRat's Avatar
KingRat
Default Panel?
I'm not sure which panel you are referring to. The factory used two grilles mounted in the corners of the rear cargo area. They are attached with four interior screws.
Old Jul 15, 2016 | 10:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Rear speakers were optional for 78. There were a pair; left and right. Post a pic of what you see. It could be aftermarket.
Welcome to the forum.
Old Jul 15, 2016 | 11:27 AM
blanman61's Avatar
blanman61
Yeh, pretty obvious now. My old eyes weren't seeing the screws originally, thought that back panel was all one piece going across. Can see the speakers thru the grill and they say Kenwood on them so probably after market. Thanks for the pictures & quick response,
To Panel Access
