Headlights not coming up
Old Jul 16, 2016 | 10:01 AM
megan.shea314@gmail.com's Avatar
Cruising
Default Headlights not coming up
So one of the headlights on my 1980 does not go up/down when it's supposed to (when the headlight **** is pulled). One of them goes up correctly and down, but the other will only go down. Could this be a leak in the hoses or something? Is it an easy fix?
Old Jul 16, 2016 | 10:08 AM
Peterbuilt's Avatar
Peterbuilt
Default Hi and Welcome.
Many times the seal (grommet) in the actuator needs to be replaced.
Just follow this how-to and you will be able to find and fix the problem.
http://www.corvette-101.com/vacuum.htm
Old Jul 17, 2016 | 09:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the hose connections on the relay for the balky light.
To Headlights not coming up
