Frame VIN Mis-stamped And Corrected
Another interesting thing would be to see the frame, stamping numbers, just before and after yours!
Wonder if they're on the registry?
alan thanks, I just found th 2nd stamp on the upper outer side of frame rail just behind the trans crossmember,that machine must have been heavy as it looks like was tilted out a bit,my #8 is light on the inside and heavier on the outside
its kind of odd that they wouldn't have put a vin stamp on the other side of the frame[passenger][not 2 on the same side and so close together]
