79 350 motor mounts
Old Aug 1, 2016 | 04:38 PM
7ron9's Avatar
7ron9
Default 79 350 motor mounts
Where can I get quality motor mounts that need to be replaced and rear exhaust hangars?
Old Aug 3, 2016 | 03:48 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
just go to your local auto parts store, its a motor mount nothing fancy.
Napa, or Advance auto, any parts place will have motor mounts or can get them quickly.
if you want original exhaust muffler hangars you will need to order them.
I would suggest Wilcox. corvette specilities
Old Aug 7, 2016 | 07:45 AM
7ron9's Avatar
7ron9
Thank you for the advice. I am new to the site and in the process of learNing it's capabilities.
Ron
Old Aug 10, 2016 | 08:04 AM
7ron9's Avatar
7ron9
Default 79 speedo/tach inop at same time
My speedometer is in op along with the tach. Tach cb is burnt so i suspect that is the prob. New speedometer cable that does not appear to be binding when disconnected from the cruise control and ok at transmission. Trip reset is binding but got it to 0000. Could this binding cause the speedo to be inop, or is the tach cb which I need to replace part of the speedometer problem. Pulled the tach and removed the cb...it's fried a bit. Should I go after the speedometer also in the dash? Both went out at the same time. New on this site but having fun
Ron
To 79 350 motor mounts
