74 hood liner
Old Aug 16, 2016 | 09:19 AM
red topless gator's Avatar
red topless gator
Default 74 hood liner
I am looking to spruce up the underside of my hood and have been unable to find anything I really like. Corvette America has the ABS plastic hood liner with the embossed crossed flags that I have been looking at. Has anyone purchased these? Looking to see what kind of quality etc.
Larry
Old Aug 17, 2016 | 09:47 AM
red topless gator
Larry
Does anyone have any type of hood liner?
Old Aug 17, 2016 | 03:03 PM
74Ken's Avatar
74Ken
Just so you are not left out there hanging, I purchased one from Gonzo before he passed away, but have not installed it yet. I will once I am convinced I will not be changing my hood.
There are places that still sell the original 'fiberglass' ones. I just didn't want to go that route.
Good luck
Old Aug 17, 2016 | 03:47 PM
jim in oregon's Avatar
jim in oregon
Larry
Larry..The ABS hood liner does look nice..but for 200 bucks over what a standard under hood insulation kit runs.(IF your '74 needs a new one) andconsidering few people will ever admire it..I'm not sure the value is there?..
Ultimately it's your car and your money-decision..
i have seen the corvette america item in their catalog..You might inquire of them how it holds up..how it's installed etc..There was a thread several weeks back by newbvette asking a similar question..Not sure what if anything he found..Jim
Old Aug 18, 2016 | 09:22 AM
red topless gator
Ken and Jim
Thanks for your responses. The hood underside is the ugliest part of my car. I may just paint the underside, and powdercoat the hood latches.
Thanks again.
Larry
Old Aug 18, 2016 | 03:47 PM
jim in oregon
Ken and Jim
Thanks again.
Larry
Larry..Gracious!..I think your engine and underhood look great..!Jim
Old Aug 19, 2016 | 08:06 AM
red topless gator
Thanks Jim, But when you look at it in the sun it looks pretty sad and needs to be freshened up.
:Larry
Old Sep 18, 2016 | 09:39 PM
kschulen's Avatar
kschulen
I purchased the abs hoodliner. I thought it was great until it started warping. The top left and right sections have warped pretty bad and don't stay in place any more. I have been trying to figure out a way to fix it or maybe cut of the top pieces.
Old Sep 19, 2016 | 03:30 PM
sierra 43's Avatar
sierra 43
I have a thick piece of heat resistant rubber that was painted with red crossed flags and the word "CORVETTE" on it. The previous owner did it. My car no longer uses the induction system The piece fits great and has proven very durable. My car has headers and side pipes and it gets hot under there. There is no clearance issue since it also has an Edelbrock performer manifold and Edelbrock carb with a drop down air cleaner.
Old Sep 20, 2016 | 07:33 AM
revitup's Avatar
revitup
I recently was going to replace my liner with an OEM type liner but quickly realized that no one sells one that is molded like the original. Decided to try to salvage mine. Removed it, laid it out on the lawn and soaked it through a couple of times from both sides with a garden hose. Hit it with a foaming carpet cleaner a couple of times and rinsed it out thoroughly again from both sides. Smoothed the fibers down as best I could and let it dry in the sun. I hit it with some flat black spray dye, sprayed the rusted retainers with underhood black and reinstalled it. Came out pretty good, the photo really doesn't do it justice.
Old Sep 20, 2016 | 09:37 AM
golfboy's Avatar
golfboy
I removed the underhood fiberglas insulation altogether and painted the underside of the hood with a flat black heat resistant engine paint. It looks much better now than having that piece of insulation stuck to the back side of the hood. An added benefit is better underhood flow of air keeping the engine compartment a little cooler.
Old Sep 20, 2016 | 12:40 PM
slofut's Avatar
slofut
Maybe this? I used it underneath my car, thinking about using it under the hood. http://www.thermalcontrolproducts.co...zeroclearance/
Untitled by Bill Smith, on Flickr
Old Sep 21, 2016 | 07:04 PM
red topless gator
Thanks. I will shy away from that and will be looking to do something different.
Old Sep 21, 2016 | 07:05 PM
red topless gator
Sure would like to see a photo of that
Old Sep 28, 2016 | 08:37 PM
kschulen's Avatar
kschulen
Actually I want to revamp this a bit. I have fixed my abs liner so it now stays so much better. Basically, you need to use a heat gun on the abs plastic liner so it forms to the hood. I also ended up using heavier duty magnets on top of what was provided. This is much better and I am happy with it. I do wish I knew all of this before hand though as then it would have looked even better.
Old Sep 28, 2016 | 08:39 PM
kschulen's Avatar
kschulen
On a side note, I will be replacing it at some point with a new hood liner that I will be building made out of aircraft insulation. I can now make these and they look really good. These are similar to what Gonzo used to make. May he rest in piece.
Old Sep 29, 2016 | 08:31 AM
sparky77's Avatar
sparky77
Dynamat makes a under hood product called Hoodliner#11905 that will keep the hood from getting hot and keep the paint nice and it looks good.
To 74 hood liner
Old Sep 30, 2016 | 09:02 AM
imariver's Avatar
imariver
I made my own . . . .
Old Oct 25, 2016 | 05:58 PM
Shovels and Vettes's Avatar
Shovels and Vettes
Toss it and forget it. It serves no purpose and is ugly.
Old Oct 26, 2016 | 07:47 PM
vettebuyer6369's Avatar
vettebuyer6369
Members- - a few posts in this thread have been removed as the discussion turned to the development, promotion and sales of items on the forum without being a Supporting Vendor.
Please do not conduct commercial sales or promotion in the open threads if you are not a Supporting Vendor. Please contact me for links to information on becoming one if interested.
