Steering Overhaul
Old Aug 18, 2016 | 10:45 AM
SDS Photography's Avatar
SDS Photography
Default Steering Overhaul
Hello, all. My father and I are going to add power steering to our '68 327. We plan on using this kit -
http://www.borgeson.com/xcart/produc...&cat=97&page=1
My question is - what else should we replace/rebuild? My father is concerned that the steering is loose, and my thought was that we might need to replace bushings in the column while having the power steering converted. Thoughts?
Also, our engine is a GM replacement 327. Will that change which kit we should use?
Thanks to all.
Old Aug 19, 2016 | 09:24 AM
74Ken's Avatar
74Ken
I am installing Steeroids myself right now. The reason was because I was tired of the old Control valve leaking all over my floor and the Borgeson did not replace that part.
When you remove the old steering box you can tell if the steering bearings/bushings need to be touched because the wheel will turn freely.
Mine turns so easily and no "grinding" that I am sure my column is good for another 40 years.
Good luck with the swap.
Ken
Old Aug 19, 2016 | 04:17 PM
GUSTO14's Avatar
GUSTO14
Thanks to all.
Check; Rag joint, Idler Arm, tie-rod ends, ball joints, and wheel bearings. All of these can contribute to loose steering.
Good luck... GUSTO
Old Aug 19, 2016 | 04:32 PM
USAFVeteran's Avatar
USAFVeteran
I also just replaced my entire steering with a Steeroids kit. No rag joint needed, and the kit comes with everything you need. I changed the pulley system with a March system, so I had to do a reservoir and have some hoses made. It wasn't a big deal, and now it looks super clean. Mine is still on stands, and I haven't driven it yet, but it sure feels good, and has a very quick response to the input of the wheel. It is a great system, and I'd recommend it to anyone.
Old Aug 19, 2016 | 07:54 PM
carriljc's Avatar
carriljc
Default doesn't the borgeson kit eliminate the old Control valve?
For some reason I thought the Borgeson conversion deleted the old control valve oily part of the relay rod? Am I misunderstanding something?
Ken
Old Aug 20, 2016 | 09:05 AM
Street Rat's Avatar
Street Rat
That is correct. At least on my '81 this was the case.
All of the leaking hoses, valve, and cylinder are removed.
To Steering Overhaul
