Vintage Air Install Question.
I did a self install on a 75 non air with Vintage air, no Freon charge yet.
When the switch for the blower motor was in the off position before the install (stock form) the fan would be on low speed, now it doesn't come on until the last two settings. In other words, on the far left and second setting there is no fan until the last two settings. It's now a two speed fan. Is this normal?
When I'm ready for the Freon charge, will any a/c place be good enough or should they be familiar with Vintage Air settings?
Maymyvetteliveforevr (09-06-2016)
One of two things that I can think of, did you test the factory switch mine was just full of goo and such it came apart easy and cleaned up well, take pics when you pull it apart for reassembly.
Did you program the unit, it is a gen IV right? It may not have taken and may require a reprogram.
That's all I've got.
Dave
Dave
Dave
Dave
I didn't realize it had to be programed, I never came across that in the instructions. Can you add more info on this?
Before I take the switch apart, I just want to be sure how it's supposed to operate. When in the off position, I always heard the fan run before, is this still the case?
Thanks for the reply and info.
I purchased the 68-76 Corvette NON-Factory Air Gen IV Complete Air Conditioning Kit Vintage Air.
However you could just reach out to VA and have them send or just walk you through it. The programming was really simple. Don't throw out any of your parts you will need one of the wires to program it.
Maymyvetteliveforevr (09-07-2016)
5th Gear
I just did a VA swap last winter and literally just stumbled across the directions that I had kept "just in case"...only problem is that was two days ago and I tossed them.
Go online to the va site and you will find the instructions there, the grey wire is grounded during the process as the previous poster described, takes about five mins to do.
Dave
Dave
I thanked everyone for your reply.
I just realized that the switch is part of the new control assembly therefore there should be no need to disassemble and clean the switch.
I still have the manual and will go through it to find the section on programing. As mentioned, I haven't charged up the system with Freon yet, therefore will that make a difference re programing or should I wait till it's been filled?
Vintage Air
I have self installed and self charged a couple of Vintage Air setups on 2 different 68's so happy to share what I found out.
1. Do good to read the whole instructions and a couple of times too. Call VA tech which is great too.
2. My fan switch worked in reverse, but I was ok since I still had an off, low and high anyway. Not sure what the problem was.
3. To charge and get the 28 or 29 oz of R134 in, you have to follow VA's instructions. Namely you have to set up fans ( I used 3) in front of the radiator / condenser to move air. Otherwise my experience is you will have a tough time getting the full charge in and therefore max cooling. Some a/c shops will not want to go to that trouble and so you get an undercharge. Consider charging yourself, you can buy a Harbor freight vac pump $100 and gauges $60 which is what I did.
4. Agree with above, the gray wire is used in the setup calibration and is in the instructions. VA instructions are online and you can download. I think you want to calibrate after you charge, but check the instructions.
Vintage Air works great and a great product for me.
Hope this helps.
Hope this helps.
Maymyvetteliveforevr (09-08-2016)
Thanks for the replies,
I haven't had a chance to review the manual and thanks for the link D_Williams.
Three things I need to do.
1. Read manual (see link).
2. Repair fan switch, (doesn't work on low)
3. Charge system (Freon).
I also noticed yesterday that my compressor (passenger side mount) is set back approximately 1/2" from the pulley. Looks like I may have to modify with bushings.
Good point and same here.
Maymyvetteliveforevr (09-09-2016)
Thanks everyone for your replies.
20mercury
I also used the outer grove on the pulley and based on my calculations I'm inset by 1/2" which isn't enough to have the pulley fly off as I don't push the car to it's limits much.
VETFEVER
It's all the little things that need to be taken care of. I had to go back and redo several things as I have the time now.
Brass Pass
Thanks for taking the time to post all the photos. Shimming out the water pump pulley will throw everything else out so I'll stick with just the a/c compressor. The ones supplied by V/A will have to be modified to make it work.
I'll try to address some of my issues this weekend.
20mercury
VETFEVER
Brass Pass
Brass Pass
Thanks for the detailed write up, I installed mine last year and can't really remember which one it came with. Looks like you did an amazing modification to the stock set up.
I do remember that it was very tight, but I was in a hurry at the time as I needed to meet a deadline and everything went so fast. This year I'm trying to tie up some loose ends but it looks as though all wont get done this year.
Installing VA in my 71 w fact air.
Im having the reverse fan switch operation problem too. Good calibration for the air direction ... and have all 3 speeds plus off. Just the OEM switch seems to be backward.
Ive heard of the early 70s trucks with this issue .... consi@Willcox Corvette for a new fan switch.
