He is still disecting #'s to determine what we have under the hood since we have non stock engine and new pieces here and there. The only thing we can find on the heads is a W. Research tells me might be World aluminum heads but stamp doesn't match the pics of the ones I have found.
Ok, so the heads are Winters, the engine 454 casting 14015445. Intake matches to 72 model 454. A post I found on Chevelle forum says 6269318 intake was intended for a boat? Wth lol I believe it is a high rise intake that I am reading about? I also hear that the reason the valve cover does not have oil add cap is that when building the engine for racing they want solid covers without the cap? I really did not intend to get this deep into it in the beginning but I have gotten so fascinated with the wealth of info available . I am starting to get an interesting time line idea on when it probably restored.
You have some interesting parts there. Keep looking up the parts numbers online.
BTW I had one of those intakes. The water ports are brass or copper lined to resist corrosion. Also the thermostat mounting. I sold it on ebay only because I was going for originality
BBC head casting numbers are under the rocker covers. IF you have the factory covers with the twist on oil cap, sometimes you can get lucky.
No oil cap. Hubby suggested he could look , I think I have talked him out of that. No reason to "fix what is not broken" I'm sure someday we will probably have to take them off for one reason or another , I think what is under there is best a mystery for now with the only reason for removal being curiosity. Probably will think about changing them out for cover with oil cap, this setup looks like a PIA to me. She has not burned a drop yet, of course we have not driven it much either.
