exhaust heat sheild
Old Oct 10, 2016 | 06:08 PM
sparky77's Avatar
sparky77
Default exhaust heat sheild
On the left side exhaust manifold there should be a tin cover so the air cleaner hot air intake can pull hot air into the carb until the engine warms up.Does anyone make a replacement mine was missing when I got my 77 L82.
Thanks,Pete
Old Oct 10, 2016 | 08:52 PM
revitup's Avatar
revitup
Corvette Pacifica has it. I saw it at Ecklers in chrome also.
http://www.corvettepacifica.com/prod...ith-air-76-80/
Old Oct 11, 2016 | 12:46 AM
bmotojoe's Avatar
bmotojoe
There are two different styles. A single hole above the dump and one with two holes above the dump. The link provided above is the two hole and would be used with A.I.R. provision exhaust manifolds.
Single hole link:
http://www.corvettepacifica.com/prod...out-air-76-80/
Old Oct 12, 2016 | 11:33 PM
sparky77's Avatar
sparky77
Thanks,Pete
Old Oct 13, 2016 | 12:19 AM
ncbuckeye3's Avatar
ncbuckeye3
Is it okay to remove that shield, is it needed? My 78 had a different air cleaner installed and the tube that goes from this to the air cleaner is gone. Can I just remove this without any negative repercussions?
To exhaust heat sheild
