I'm an owner of a beautiful 77 T-Top Corvette. Sadly the previous owner did some ugly upgrades, interior modifications and a horrible paint job. Now I would like to fix that and bring back the beauty of the factory condition.
But I have now idea how I can find out how she looked when she was born.
With german cars it's quite easy to ask the manufacturer and even get a certification when you finished your restoration.
So I hoped you can help me find out who i need to ask or what I need for that.
The trim tag inside the driver's side door will show the original colors, inside and outside. A little sleuthing and deduction usually is required too.
There were several changes made to the 1977 during the production run, so knowing if you own a late or early model is important. Most people say the cutoff point between early and late is at serial #1Z37x7S427373. Around that time the alarm switch was moved from the drivers fender and incorporated into the driver's door lock. The change from 19 pin t-top weather strip to 18 pin occurred after that point. Having a copy of the invoice will help with what your car came off the production line equipped with, and where it was delivered to. Wow! $50.00 now for a copy. Mine was free, but that was a long time ago. I own a low mileage late model L48 A/C auto 77 that is mostly original if you have any questions I can try to help.
"Corvette 1968-1982 Restoration Guide" by Richard Prince will give you a lot original pictures of how these cars were built.
Originally Posted by n3Xar
Sadly the previous owner did.....a horrible paint job. Now I would like to fix that and bring back the beauty of the factory condition.
Remember that back then these cars were painted at the factory by men in a hurry, not machines. So the paint was not without flaws. The restoration guide says runs, over spray, and poor coverage at the lower sections was normal.
A good many restorations actually end up making the car look better than it came from the factory. The suggestions above for the NCRS and restoration guides should help you a LOT to determine how to get what you want.
