Help me pick exhaust system for 74 base engine
Exhaust is tired and has leak where passenger side manifold meets exhaust pipe.
i realize that alot of a 'mean/lumpy' growl from an exhaust is not the exhaust itself but the engine - but i want the car to sound meaner that it really is.
I don't like exhausts that have a high pitched drone..that reminds me of the kids in their dropped foreign cars ala Fast and Furious, but rather a deeper, throatier sound.
i've been looking at Corvette Central's kit but have no idea who makes it to know what it even sounds like or what kind of reviews it gets.
Willcox also put up a couple of nice YouTube videos for him chambered exhaust and Stage II systems but both cars he had that on had modified cams so i know i won't get that full effect as the video showed/sounded, but nonetheless i'm leaning towards one of those.
i do expect to rebuilt the small block in the future and a new cam is part of those plans - so i'm okay putting in an exhaust that i know sounds good now, and will sound even better later.
that all said - any pointers or recommendations ?
TIA !
Also found this..
Header Guide 1
Header Guide 2
Duane
chambered are basically straight thru pipes, will be way too loud for a street application, except for the youngsters who want it loud.
I have aluminized from front to back. 8 years old and no sign of patina or age (maybe a couple of oil drips and stains)... lots cheaper.. I also have the stock sounding mufflers.. probably too quiet for what you are asking.
you probably might want those magna-flows. do a search, there are several sound bytes out there to chooses from to help you decide.
a front to back set of aluminized with magna flows would be sweet on your car. while you are at it, hit your exhaust manifolds with high temp paint in cast iron color.
https://www.summitracing.com/parts/p...YmhRoC17fw_wcB
I disagree. My chambered pipes are not loud at all. Nice deep tone that opens up a bit when under throttle. If you have a built motor with a cam and higher compression, then it may get noticeably louder. He has a stock 190HP motor though.
put a chambered system with glass packs on my base '72 for the same reason and it sounds fantastic. Looks cool too
