1975 and 1980 frame differences?
Old Dec 19, 2016 | 08:00 AM
Akodo's Avatar
Akodo
Default 1975 and 1980 frame differences?
Hey all,
I'm starting work on my 75, finally, and this requires a second frame to do it the way I want. Theres is a very nice 1980 frame for sale in my area, my question is, will it work with my 75 body?
I want to build the frame up separate, drop and LT1 from a 96 into it, then remove my 75 body and just drop it down on top, thereby letting me restore the original frame/engine setup to pristine condition while I use the other as a daily driver. So will it work? What is different between the two frames?
Old Dec 19, 2016 | 08:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
http://www.71corvette.com/frames.html
Keep in mind, fuel tank filler neck location changed beginning in 78.
Old Dec 19, 2016 | 11:27 AM
Ibanez540r's Avatar
Ibanez540r
Fuel tank mount and style are different, but can be made to work with some fabricating.
The larger issue in your situation is the differential / cross-member. 1980 went to a completely different design.
74 will work for you, just a different rear impact bumper design. 75 76 & 77 will be a direct swap, 78 & 79 will require addressing the fuel tank noted above.
73 & below have chrome bumpers, 80-82 have the new differential & cross-member.
Old Dec 19, 2016 | 01:23 PM
Akodo's Avatar
Akodo
Thanks guys, that link was particularly helpful too. Guess I keep looking for a 75-77 replacement in decent shape, seems the better route.
To 1975 and 1980 frame differences?
