Lol I wish... Just finished up bleeding the system and the pedal goes to the floor. It's firm but to the floor. And just to see started the car put in D and slowly let up on the brake. Now I said slowly so the half shafts barely turned over but anyway as soon as I started to let up they were turning. This is exactly how the poem m/c acted too.
I looked under the dash which is almost impossible and don't see or feel any adjustment. Also though however the pedal doesn't feel firm when it's not running so either I still have air in the system or it's the booster??? Ever since I replaced the booster I've had non stop problems with the brakes. So what's my options now?
without the motor running you have no assist so the pedal should be firm .
if your rod length is still too short you will have trouble getting a good bleed ,unless you go with a gravity bleed or one of those pressure bleeder pots .
the symptoms you are describing fit both air in system and rod length too short . If it were mine I would be measuring as asked before and see what numbers you come up with.
on the end of the threaded rod that comes out the back of the booster is a screw on piece , that piece is a y shape and goes over your brake pedal arm with a pin securing it together , to adjust it you must undo it from the brake pedal and wind it in or out to lengthen or shorten the rod throw. that's your adjustment .(with a lock nut to nip up against that y piece to stop it undoing by itself )
Ok I'll try that but there is no threaded anything. There is a rod that comes out of the booster that has a squared off area for a 10mm wrench I guess to turn in out out. Now I've been checking other items and this is weird but with the m/c plate off I can jam the brake pedal hard and absolutely no fluid movement in the reservoir. I would think you would see something. I did that starting off real slow not to splash fluid all over.
Where the rod enters the booster there is a rubber boot so is it threaded beyond that and is why I don't see a threaded part? Just making sure.
Another thing is I went to Wilwood's site to double check bleeding procedure for there calipers and they have bled by gravity so just curious I opened a bleeder screw one at a time on each caliper and got nothing out of it??? Really scratching my head now. Unless it takes hours to do I just did it for a couple minutes but would think that would be long enough...
Measure? I have nothing to compare it to and that would mean removing the booster right?
I did bleed the system with a bleeder pot and removed roughly a bottle size of fluid out from the four calipers.
I removed the booster b/c I couldn't see crap underneath and there is no adjustment whats so ever! All that work for nothing... Not sure on what to do now?? I was able to pull back on the pedal about an inch when I was removing the booster nuts so I thought good it's out of adjustment but nope...
you didn't need to take the booster out . what I was trying to tell you was it might need adjustment , but at least we know there is no adjustment at the back . which leaves the front rod .
as for 1 inch to 1 1/4 rod extending when you put your foot on the pedal ,forget about that ,its where the rod end sits in relation to the join face at rest is what you need to measure .
by looking at your pic it looks to sit lower than the join face, put a small straight edge across the hole and measure down from the edge to the top of the rod . Just say it is one quarter of an inch lower .
Now measure the same join face on the master to the piston where that rod will push against , it should be just short of one quarter inch RAISED , so when you bolt them together the rod is close but not touching the piston
ok thats out of my 69 , the rod is in as far as possible and you can see how far it sticks out compared to yours , last pic is the weld mark after adding more rod to make it work, car ran fine
I measured both and it's right on the money. Since everything was back off I decided to re-bleed the new Wilwood m/c and sure enough it still had air in it. So I took my time to bleed it throughly and now tonight I will start reassembly. But before the dash goes in I will make sure my brakes are solid....
Mine is the same no adjustment rod just the black cylinder coming out of the booster. Brakes are soft and do not lock up. Pedal almost to the floor before stopping
Reason: Spelling
did you ever get your issue resolved? I am fighting the same, I even reverse bleed my brakes I believe there is no air, i feel good about my bleed. I think it’s the rod coming out of the booster to the brake pedal.
