Caliper mounting bolts size?
Old Jan 28, 2017 | 06:40 PM
antoniov1's Avatar
antoniov1
Default Caliper mounting bolts size?
I seem to have misplaced my bolts after rebuilding the calipers to the o ring conversion. What is the size of these bolts? The bolts that hold the caliper to the flange. Not the bolts that hold the two halfs together. Thanks!! Are they the same size for the front and back?
Old Jan 28, 2017 | 09:57 PM
'75's Avatar
'75
Same front and rear, 7/16 fine thread.
Old Aug 5, 2022 | 12:20 AM
Cooter77's Avatar
Cooter77
7/16 20 fine threads shorter bolts (C3) go on the rear. Slightly longer ones on the front.
These are the ones that connect to hub, not the bolts that holds the caliper together...of course they are larger.
Old Aug 5, 2022 | 11:04 AM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
They probably figured it out 5 years ago
Old Aug 7, 2022 | 09:19 PM
Cooter77's Avatar
Cooter77
May be helpful for the next person who are researching similar problems. They are there for our research, regardless of the age.
To Caliper mounting bolts size?
