Tire question (Asking input)
Old Feb 8, 2017 | 08:49 AM
golfboy's Avatar
golfboy
Originally Posted by 69autoXr
Was the front of the car on the ground when you tightened the control arm bushing bolts?
I can't answer that question. The PO replaced the front bushings before I got the car and I just recently replaced the rear spring bushings.
Old Feb 8, 2017 | 09:00 AM
Sunset Orng 05's Avatar
Sunset Orng 05
Veteran: Marine Corps
I don't want to hijack this thread but I may have a similar issue. If the car was not on the ground when the control arm bushing bolts were tightened would it be as simple as loosening the bolts with the car on the ground and retightening?
Old Feb 8, 2017 | 09:48 AM
69autoXr's Avatar
69autoXr
Yes, but I'd also either roll the car back and forth or drive it around the block to settle the suspension before tightening the bolts back up.
69autoXr's Avatar
69autoXr
Might be worth looking into.
Old Feb 8, 2017 | 11:16 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Yes, but since it could apply to both the the upper, as well as the lower control arms, you'd to have the car either on ramps, or a "drive-on" lift, so you could access all the bolts.
