tcs solenoid stud
Old Feb 7, 2017 | 07:37 PM
Makonut's Avatar
Makonut
Default tcs solenoid stud
Okay, on a base 70 300, which hole should the stud be screwed into on the manifold going from front to rear on pass. side. Not actually hooking it up to work full time, but want the correct look.
Old Feb 7, 2017 | 09:32 PM
Corvetteoz's Avatar
Corvetteoz
This is on a 72 but I presume it will be the same. Should get you pretty close.
Old Feb 8, 2017 | 10:42 AM
Makonut's Avatar
Makonut
Thank you.
To tcs solenoid stud
