Plastic Fantastic tew
#61
I just couldn't leave that one in the block
pushrod checking length - as is normal, one of the checkers won't work because you can't get the jam nut past the guideplate
which lead to another issue... there's an interference between the head and the piston
cute,no?
the repair
see the straight edge? it's designed for the older, closed port heads
now it's all heart shaped.... and an interference.
yeah, precision work....
I'm still not sure I took enough off but until I get clay and check that along with the valve clearance, at least it doesn't hit on rotation. I'm going for .050 clearance
pretty, even with the missing tooth
the water pump is on because I can - not because I should
cute,no?
the repair
#63
Nam Labrat
Received 4,179 Likes
You're "ironing out" the problems and making progress.....I'm jealous.
SuperBuickGuy (09-28-2017)
#64
first things first.... replace the plug
then measure for new pushrods
verify that nothing is going to hit (and who says I'm not crafty?)
at least .0740 of clearance
verified both sides
stack it all together again
which brings the new problem.... I ordered the wrong head bolts, in case anyone is copying this - the heads are similar to a Profiler 18 or 24, so those are the head bolts to get. Ah well, it's all moving the right way
verified both sides
#65
test fit time
with supervision
this was a bit spun up because a balloon went over....
hmmm, nice balance
let's try that again
take wheel off.... life is easier until I finally build a gantry
almost like GM planned it this way
part one was how tall of valve cover would fit
this is why there is a big hit on the header tube from OBX - still looks like crap
miles of room
and the other thing I needed to know - how much scoop
certainly won't be doing a tall filter but it looks like just enough clearance for my L88 scoop
with supervision
hmmm, nice balance
miles of room
#66
so, other then the DD distraction, parts are coming together to move forward ..
first, and oh how I loved the howl last time I changed the rag joint for a solid borgeson joint.... these are the bits to remove the power steering and the rag joint
and I got the pushrods
now it's time to start pulling the stuff down for the rest of this build
I'm sure someone, somewhere needs this cowl hood and wants to trade me for their flat one - so I can put a different scoop in it. The guy who did this did a reasonable job installing the scoop so it seems kind of a shame to cut it one up
#67
I was right, dammit, I was right. But before the details....
got the pins for the bellhousing
yes, extra long, not sure that's a good idea but it's what I've got
part of the day was cleaning the engine bay - which happened after the motor was removed
not terrible, but dirty
much better
after it dries, paint...
pulled the pan off to do the mods I need to finish on it
you'll note the engine doesn't have heads on it.... that's because the chinesium head bolts broke at 74 lbs....
I knew it. I knew I should have just bought ARP studs. They're $220 (that I would have had to buy twice because I would have bought the wrong ones first).... The chinese heads are profiler 24 heads that require a bit shorter outside bolts and 1" longer bolts across the top of the exhaust ports... ah well, I'm seriously just one crank away from having a complete 2nd BBC with all the spare parts.... did I mention that I was building another 427? this one is a gift for my dad and his 65 Chevelle SS (no telling).
much better
#69
today, remove such silly stuff as steering
first remove power part
it's in good shape (painted pretty)
move the tie rods to the manual hole
move the Buick to the Fiat hole, the the Fiat to the Corvette hole, then the Corvette to the lift
time to start cleaning it up
all of these have issues - but between the all, I think I have one good one
finish remove steering
pretty part... wrong one.... again, this is a 48 spline 1" and a 30 spline 3/4.... which is exactly what I didn't order
I did, however, get medieval getting it apart
so I'm kind of stopped there for a moment - no worries, there is much I can do.... what? well, you'll just have to tune in next time on As the Corvette Flops.
#72
Nam Labrat
New paint
#77
back to 427s
box of receipts, most importantly the lash adjustment (16,18)
shortened the dipstick so it reads accurately
lash adjustment
and yes, I need a touch taller valve cover
intake manifold glued in place
test fit the side pipes
it'll do
My goal is fired it a week from Sunday - that actually means driveable
lash adjustment
it'll do
#78
bloody hell that was a pain to find.... no special-material-distributor gear required - this from Comp Cams web page http://www.compcams.com/Pages/402/camshaft-cores.aspx
Street Roller Cam Cores (Hydraulic or Solid Roller)
(special material - works with most standard distributor gears)
01-000-8 CHEVROLET 454-502 Generation VI Big Block
07-000-8 CHEVROLET LT1 Engine
08-000-8 CHEVROLET 262-400 V8 with Roller Cam (1987-98)
09-000-8 CHEVROLET 4.3L V6 with Roller Cam (1987-98)
11-000-8 CHEVROLET 396-454 V8 (1967-96)
12-000-8 CHEVROLET 262-400 V8 (1957-98)
18-000-8 CHEVROLET 4.3L V6 (1985-99)
56-000-8 CHEVROLET 4.3L V6 (1992-99) with Balance Shaft
#79
so a bit got done. First was get the balancer on - which meant taking it off because it wasn't fitting correctly
now it does and brake clean does wonders getting the paint off
I'm glad I test-fit the headers - I need to get medieval on this header otherwise the plug doesn't come out
I also did some test fitting
why have a box when you can have a sexy, shapely girl?
basically it's just sitting on there - so now I can daydream on how it all will fit together.
and some fitting is required (a lot)
How I ended up with 2 shifters is a mystery to me - but it's good because wretched excess is a good start.
#80
an occasional update
time for flares
add heat
and pop, off it comes
and the new sitting in place
time for an executive decision on where to splice this together
chop chop
The CIC flares don't wrap all the way under, nor does it maintain this edge - even if I fill it, I want the strength so here's what I did
rough cut
seems to be going the right direction
I plan on filming a YouTube video of the second side when I do it, but here's the comparison to 'before'
now you can really see how much extra flare there is
and the back, again
a picture of how much of the back is bonded
I think I want the flares bonded in place before I finish the fuel system, which isn't a huge deal because it's really not going to be driveable for a bit longer
time for flares
add heat
chop chop
rough cut
and the back, again
