Steering column disassembly
Old Feb 18, 2017 | 12:29 PM
vmsns007's Avatar
vmsns007
Default Steering column disassembly
trying to tear column down on my 74 non tilt column to get to the turn signal switch that's broken. Removed the aftermarket wheel PO installed and this is where I'm at now. How do I get this extender off to get at the column guys underneath ?
Old Feb 18, 2017 | 03:11 PM
vmsns007's Avatar
vmsns007
Figured out I needed a steering wheel puller and was able to get this off. Of course now I need a lock plate remover. Always a tool I don't own !
Old Feb 19, 2017 | 12:14 PM
TimAT's Avatar
TimAT
Most autoparts stores have a rental program going. They should have one.
Old Feb 19, 2017 | 07:18 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
and once you get below the hub you'll see the shaft has a retaining ring that you'll need to remove as well.
Willcox
To Steering column disassembly
