Morning Everyone, Just found out that the valve covers are leaking On my 1970 Corvette 350/300HP Auto. Last part of the restore is leaks..... Instead reinventing the wheel can someone tell me the proper material, vender, and proper procedure they used in stopping the leaks. The valve covers are original steel and I do have an original pair of OEM aluminum covers. I used a pair of original cork gasket from GM when I rebuilt the engine. Torqued the covers to the proper spec. The valve covers are flat and straight no dings or dents.. Thank you Droop... PS I have a feeling that leaks will be unending due to the Corvette sitting for long periods of time.
My 72 SB was leaking there, the pan, the main seal, and the intake manifold was leaking coolant. I think this was a result of the car sitting up and infrequent driving. All of it is now sealed and the parts were from Paragon and it no longer leaks oil. I don't have the part numbers but Paragon has a great online parts store that is easy to use.
Good Luck
I will assume you used cork because you are doing a point restoration.
I recently went through the same with leaking covers using cork so I went with aftermarket rubber for my rebuild. No more leaks. My car is a restomod so originality is not that important to me.
Install tip: Just like installing a windshield, torque the important sealing edge first to get the best seal. In the case of valve covers torque the rear bottom bolt first, the front bottom bolt second then the top bolts.
If going with the OEM aluminum covers use Fel-Pro #1628 gaskets and they will never leak again.
FWIW: Unless you are going NCRS this is a no brainer to me as I love the OEM aluminum covers.
Ice, I will being using the aluminum covers. Would like to have a pair for the original steel covers also....What was the torque spec for the covers you used? Droop
Dynra, thanks for the information.. What torque spec did you use for the covers? Droop
Whatever the stock torque is, which is very light. The Fel-Pro gaskets have a crush ring so you can't over torque them. They are also reusable and require no glue or sealer. The Fel-Pro are pretty much idiot proof.
Ice and JR, Thank you very much. Leak problem solved...Droop
