OEM Urethane Rear Bumper Question
Old Mar 8, 2017 | 05:49 PM
JohnnieUtah's Avatar
JohnnieUtah
Default OEM Urethane Rear Bumper Question
Is it possible to take waves or a sag out of the OEM urethane rear bumper using a heat source and then allowing it to cool in a restrained condition promoting a flatter condition?
Old Mar 8, 2017 | 07:24 PM
Priya's Avatar
Priya
I had a rubber like (AMC called it "Krayton") bumper corner on my 81 AMC eagle that had been bent out of shape for years. I used a heat gun to try to straighten it out. After a minor improvement I ended up cutting out and shaping a mirror image of the warped area out of wood. I pressed the bumper corner against the mirror image wood piece, heated it with the heat gun and let it cool more times than I cared to count. It improved a great deal but still wasn't perfect.
I think a lot will depend on the size of the warp you're trying to address. The area I was working on was perhaps 6 or 7 inches long. If its really big I don't think you're going to be able to manipulate it as needed. Also, if you use too much heat you could ruin the piece. I painted my bumper corner after the work, so if you're not planning on doing that I'd be pretty hesitant to try it.
Old Mar 9, 2017 | 08:17 AM
JohnnieUtah
Mine's going in for paint on the bumper only and I'm hoping that they can remove some of the sag out. Too bad I didn't get more responses
Old Mar 9, 2017 | 10:22 AM
Priya's Avatar
Priya
Bump the thread to the top after a couple of days and hopefully someone else will respond.
Old Mar 9, 2017 | 10:28 AM
Priya's Avatar
Priya
Perhaps post a picture of your bumper cover and what specifically you're hoping to change about it.
Old Mar 9, 2017 | 07:04 PM
bazza77's Avatar
bazza77
with out a pic or even a description of what's actually happening its hard to say something useful .
Is all the crash bar and bumperette(not 74) pieces still bolted on the car ?, the cover follows there shape very closely .
I have seen a 77 with what was described as "eyebrows" they were a wave above each light hole . the cure for that was to loosen the fittings and retighten without forcing anything together . I think the bumper was put back on starting at one end and tightening each bolt as they went which was wrong way in that case. They redid it by putting all bolts on and tightening in sequence like putting a cylinder head on a motor.
Anyway hope that helps , new paint is always exciting !!
To OEM Urethane Rear Bumper Question
