1972 horn relay.
Old Mar 8, 2017 | 06:42 PM
540 vette's Avatar
540 vette
Default 1972 horn relay.
I can't remember a car that I have had that had a horn relay. What does it do and what are the wires for that hook up to the lug on it.
Old Mar 8, 2017 | 07:32 PM
RMS73's Avatar
RMS73
When you press the horn button on the steering wheel a coil in the relay is energized and closes a contact. This contact allow current to flow from the battery or fuse panel directly to the horn. This is done so the high ampage needed for the horn does not flow thru the wiring in the steering column. The relay is mounted under the fender just behind the drivers front wheel well. I don't remember the wiring colors and routings.
Old Mar 8, 2017 | 09:01 PM
540 vette's Avatar
540 vette
I think I am more concerned with the wires on the lug that is on it. What do they take power from there or is it a junction.
Old Mar 8, 2017 | 09:24 PM
Richard454's Avatar
Richard454
It's a junction and a relay-
Alternator- fuseible link from the starter- power to ignition-headlights
also where your Ammeter reads from
Old Mar 9, 2017 | 04:07 AM
540 vette's Avatar
540 vette
I have the wiring diagram but was curious of what the wires connected to the lug did. I am running a one wire alternator and installing an autometer voltage gauge. Which of those wires is no longer needed.
Old Mar 9, 2017 | 08:57 AM
Richard454's Avatar
Richard454
I'm not a big fan of one wires Alts...there's too many trade-offs for a street car- read this-
http://www.madelectrical.com/electri...hreewire.shtml
I'm going to assume (usually not a good idea) that the new alternator has more output than the stock one. And you are going to change the output wire of the alternator to a larger wire. And if you are adding some large draw devises like electric fans- the stock wiring was never intended to handle that amount of current.
Another good read-
http://www.madelectrical.com/electri...evymain1.shtml
Richard
Old Mar 9, 2017 | 09:59 AM
BLUE1972's Avatar
BLUE1972
I would run a heavy wire to the battery terminal of the starter and also tap that for any electric fans. Or run it to the battery.
With the one wire and volt gauge you only need the charge wire. Light and amp gauge will no longer work.
Old Mar 9, 2017 | 01:49 PM
540 vette's Avatar
540 vette
Another good read-
Richard
I am running 8 gauge from the alt to the stater lug and running all new wiring for the fans. 100amp alternator.
I have been using this type for many years with no problems.
Old Mar 9, 2017 | 02:56 PM
Richard454's Avatar
Richard454
As a rule of thumb- underhood wiring because of the temps- move up one size - 8Gu is on the line- 6GU would be better. The current rating is at 70ºF-with a 540CI that'll be passed soon after you start it!!!
You can just get rid of the horn relay all together- add a much more reliable Bosch relay for the horns- depending on year loose the key buzzer.
Something like this would clean it up-
To 1972 horn relay.
