Rear end groan
Old Mar 12, 2017 | 07:16 PM
Sophocles's Avatar
Sophocles
Default Rear end groan
My 71 convertible groans when I turn left or right while moving. No noise when turning front wheels while still. diff fluid seems full and clean (Limited slip 80-90 gear oil) Any ideas. thanks!
Old Mar 12, 2017 | 09:09 PM
drwet's Avatar
drwet
There is a special posi additive required for Corvette limited slip differentials. Get some. Add it. Do some figure eights in the nearest parking lot. Chances are that will take care of it.
Old Mar 12, 2017 | 09:17 PM
hope2's Avatar
hope2
groan or chatter? groan power steering, chatter diff.
Old Mar 13, 2017 | 03:16 AM
72downunder's Avatar
72downunder
not the dreaded circlip rolling around in the diff noise is it?
Old Mar 13, 2017 | 12:14 PM
blue by you's Avatar
blue by you
I would drain the diff add new fluid and put in the additive for the posi go do some figure 8's in a parking lot and you should be good to go
Old Mar 13, 2017 | 01:23 PM
mike1969's Avatar
mike1969
I can give my experience with the diff. I was at a light and turned right and within about 150 feet there a sound like a metal hammer hitting the underside of the car. After investigation - it did end up being the diff oil so I changed it and added 8oz of TransX (suggested by my local Corvette restorer - the clutch plates in the diff were rubbing). It was pretty easy to take care once I figured that out. The only sound I have left in the rear now is a groan when you push the rear end sideways (parked) - I was told it is probably the rear leaf spring liners so that is on my list this year to look at.
Old Mar 13, 2017 | 01:58 PM
71 Green 454's Avatar
71 Green 454
Also, I use 2 bottles of GM additive.
Old Mar 17, 2017 | 05:27 PM
Sophocles's Avatar
Sophocles
Thanks for the suggestions. Is the pictured 85W-145 limited slip gear oil? I'm wondering if I ought to be adding the additive to gear oil that is labeled limited slip.
Also I'm wondering if 80W-90 is a better weight for my conditions? I'm in California's Central Valley, so it's rarely much below freezing (and I won't be driving my vette then!), but does get over 100 degrees F during the summer when I might be driving.
Old Mar 17, 2017 | 08:03 PM
71 Green 454
The fluid in the photo was recommended in the thread below, post #8.
https://www.corvetteforum.com/forums...diagnosis.html
I used the GM fluid and additive previously in this photo, but found the Lucas 85/140 along with 2 bottles of GM additive to work better.
Old Mar 24, 2017 | 11:07 PM
Sophocles's Avatar
Sophocles
Because there is no groan when I'm stationary but turning the front wheels back and forth, I'm assuming it is not power steering. Am I overlooking something?
Thanks.
Old Mar 25, 2017 | 02:49 AM
72downunder
Thanks.
Is the noise coming from the front or the back, and only when your moving (forwards/backwards)?
To Rear end groan
