Motor Madness - How Many is Too Many?
Senior Member
Received 2,031 Likes
St. Jude Donor '10
Once again I find myself in the interesting position of having three (3) corvette motors sitting in my storage area garage with no formal plans what to do with each of them, yet, but I will.
One engine is an original 1971. It's lower half, heads, and intake all match. Intake and heads are off of it now. It will be taken down to parts soon and cleaned/inspected. It is a 350/270 base engine. I will consider a .030" bore and taking its hp up to 350.
Second engine is affectionately called my 68 Franken-motor. It is assembled using a 68 lower half, 78 heads, and an 82 aluminum intake. I will disassemble it completely down to parts soon and document what I have. This 327/350 bare block may be worth cleaning up and preparing for a rebuild. Not sure yet. Might just finish it out with new top half components and boost that power a little more to 400 hp. Might bore it, not sure yet, have to see what we have there.
Third engine is an original 1975 complete engine with matching heads and intake, dizzy, and starter. I will pull the dizzy out, pull the starter off, remove the valve covers, heads and intake and see what I have.
This engine was running when I got it. I will investigate rebuilding it and adding a new cam, heads and intake for a little bump in that base 350/165 to something closer to 300 hp. Bore .030" over and see what she can do.
All three have lots of options, share your thoughts, ideas, learnings you have from building your engines here please.
Appreciate your ideas.
Best regards,
David Howard
AllVettes4Me
Best regards,
David Howard
AllVettes4Me
Senior Member
St. Jude Donor '10
Seems like a lot of time and money to build three separate engines that range from 300hp/350hp/400hp. Not really a huge difference between each of them.
What is your goal in all of this? How will the engines be used? What is the point of building a 300hp engine?
Senior Member
St. Jude Donor '10
David
AllC34Me (03-17-2017)
Senior Member
St. Jude Donor '10
Senior Member
St. Jude Donor '10
Senior Member
St. Jude Donor '10
Worth a thought. Thank you.
David
Senior Member
St. Jude Donor '10
David
Just a well intentioned FYI - the "lower half" of the engine is called the short block. That is the assembled block, crank, rods, pistons etc.
Also, if your C7 has its original engine, it is an LT1 or LT4 (Z06).
Senior Member
St. Jude Donor '10
Senior Member
St. Jude Donor '10
I am brand new to the C-7 World and have much to learn. It is an LT1 matched to the MSU Eight Speed Paddle Shift Automatic. Mine is the 2LT equipment package. Have almost 250 miles on it now. LOL.
Thanks again for the help, much appreciated.
David Howard
AllVettes4Me
