Vin # ???
Old Mar 28, 2017 | 02:16 PM
joescvette's Avatar
joescvette
Default Vin # ???
I have 66 w/matching #'s 427,390 4 speed. But trans #'s are 3925660 main case, 3857584 tail, 3950306 side cover. P9C24A vin 19N630055 or 19N638055 on trans. what is this off of. Thanks
Old Mar 28, 2017 | 02:25 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Probably a Camaro. N is the plant code for Norwood (CA). Norwood built Camaros.
Old Mar 28, 2017 | 06:22 PM
gbvette62's Avatar
gbvette62
The "660" main case was used for all 68-69 Muncies (M-20, M-21 & M-22). The "584" rear extension housing was used on 66-70 Muncies with the right side speedometer fitting, and the "306" side cover was only used 69.
"P9C24A" is the date code, and translates as a 69 model year Muncie 4 speed, M-20, assembled on March 24, 1969. "P" is a Muncie 4 speed, "9" is the model year, "C" is March, "24" is the day of the month and "A" is an M-20 (B for M-21 & C for M-22).
The VIN appears to be for a 69 Camaro built at Norwood OH. "1" is Chevrolet, "9" is the 69 model year, "N" is Norwood, OH, "630055" is the production sequence number, or VIN. The only thing I'm not sure of is the "6" in the VIN. That's a control number that remained the same for all cars during the model year, and my info shows that it should be a "5" for 69 Camaros, not a "6"? Norwood built both Camaros and Firebirds, but if it was a Firebird trans, the first digit would be a "2" for Pontiac, not a "1".
So it appears that you have a 1969 wide ratio Muncie 4 speed in your 66, likely out of a 69 Camaro.
Old Mar 29, 2017 | 12:11 AM
joescvette's Avatar
joescvette
Thanks for all the infor.
Old Mar 29, 2017 | 10:57 AM
20mercury's Avatar
20mercury
Default Thanks too!
Thanks too!
My 68 has a P0C13B 10N52211 4sp Muncie and I have been thinking it came out of a p/u truck.
I got the 1970 March 13, close ratio part but could not figure out the "N" source, so that is Norwood and likely a Camaro.
Thanks again!
To Vin # ???
