Hardtop attachment?
Old Mar 29, 2017 | 10:31 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Hardtop attachment?
What type of "bolts" are correct to hold the 74 hardtop secure at the rear seal? Is it the same taper point like on the ragtop OR is just a threaded bolt, then using a washer and nut to secure?
Thanks....
Old Mar 29, 2017 | 10:50 PM
71 Green 454's Avatar
71 Green 454
Thanks....
On my '71, I use studs/washers/nuts along with a center stud/washer/nut and 2 side bolts.
Here's a good thread about hardtop studs vs pins:
https://www.corvetteforum.com/forums...top-studs.html
Old Mar 30, 2017 | 07:12 AM
fotyfobravo
THanks! That thread was very good. I think I will use the washer / hand nut method with a clear gasket to protect from paint rub. It rattles when using the factory pins.
To Hardtop attachment?
