Front wheel movement
Old Apr 1, 2017 | 09:15 PM
mpro71vette's Avatar
mpro71vette
Default Front wheel movement
When I put my hands at 12 and 6 and try to move it, it moves a little. Just a little play, does this mean I need new ball joints? I have a 71.
Old Apr 1, 2017 | 09:39 PM
JimT's Avatar
JimT
If you are turning the steering wheel and feel "slack" before the wheels actually turn, your steering box may need a little adjustment, or, replacement.....
Old Apr 1, 2017 | 09:44 PM
mpro71vette
No not steering, when it is jacked up it moves back and forth s little. I'm currently installing borgeson steering, that's how I found it.
Old Apr 1, 2017 | 10:11 PM
MISTERZ06's Avatar
MISTERZ06
check your wheel bearings
http://www.corvettemagazine.com/tech...g-replacement/
........................................ ...... tom
Old Apr 1, 2017 | 10:19 PM
USAFVeteran's Avatar
USAFVeteran
That's the best first answer. If, after adjusting/regreasing the bearings, it still does it, then start looking at the ball joints. They are pretty hard to move the way you are describing, but things happen sometimes.
Old Apr 1, 2017 | 10:23 PM
mpro71vette
Thanks guys, I'll check the wheel bearings.
To Front wheel movement
