Doing a complete interior restoration and in the process of fixing the tilt/telescope, broke the lock plate retainer (c-clip / keeper, etc.) and found out today that this part is considered obsolete by Chevy -they don't show it in their parts books.
Called Corvette Pacific, Ecklers and Mid Western Motorworks along with a corvette recycle yard (Beano(??)) and found nothing.
Anyone out there have one, just lying around?
Pops
I might, but would need to see a picture. I have a couple of partial columns lying around. What year C3 are we talking?
I am not sure how it broke - my neighbor who is helping is a certified mech and has a "gazillion" tools - all of a sudden heard a "ping" and it was broke.
I really appreciate the help - should you need any help in finding a part (Chevy or Ford), let me know.
For the price and ease, take Ernie's offer there man.....can't beat that with a stick.....
but in the future, I would fashion one out of steel myself in the garage, OR if you have both pieces, just weld them together, and finish off as necessary......
and mine is broken too, but I just put in both pieces, and it's been fine for some 22 years now.....
Noticed y ou are from Orange Park - I grad from OPHS MAANNYY years ago. Where in OP are you located?
I gotta ask... how did you break it? Do you have the right tool to collapse the column plate?
Ernie
Ernie,
That retainer was originally manufactured out of urethane material (the same stuff that has caused those rubber C3 bumpers to disintegrate). It is nearly impossible to remove the original retainers without them breaking into many pieces. The retainer can be removed and reinstalled without the lock plate being compressed. The retainer serves two functions. As a critical safety part it prevents the C shaped clip from migrating out of the upper steering shaft. Without the C-clip in place, the entire steering wheel, hub, and upper steering shaft can be removed from the column (even while driving down the road!!) The other function is to isolate the big telescoping spring from contacting the metal locking plate and causing the horn to blow continuously.
Jim
Here is a picture of the locking plate, upper steering shaft and the C-clip being installed. Since the inside edges of the clip are parallel a more correct name should probably be "U-clip".
Ernie,
Jim
Jim I'm confused now.... The retainer (c clip pictured in H2 Below) is what he broke.. are you saying these were made out of urethane? I've never seen one out of that.
The insulator that goes over it, yes... I break those every time I remove one.
