odd block stamping, any help?
Old Apr 18, 2017 | 04:20 AM
zim64's Avatar
zim64
Default odd block stamping, any help?
got a friend with a 76 basket case, he was wondering what this block came out of...I think the letters indicate 1975 truck/van/bus...other than that the first set of numbers(and letter) appear to be a VIN, with the last 6 numbers being the sequence of build, but I can't find what the C74 part of that stamping is...any ideas?
Old Apr 18, 2017 | 06:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
TYU indicates a 75-77 350 truck block with AT. K is the plant code for St. Catherines, Ontario, Canada. The second stamp may be a VIN.
Old Apr 18, 2017 | 06:53 AM
gbvette62's Avatar
gbvette62
I agree the "TYU" is a large truck 350. The "K" indicates the St. Catherines Ontario engine plant. In the VIN stamp, the "C" is Chevrolet truck, the "7" should be 1977, the "4" as the third digit indicates the Scarborough Ontario assembly plant, and the last 6 are the VIN.
Old Apr 18, 2017 | 09:48 AM
emccomas's Avatar
emccomas
As started earlier truck 350, 1975-1977 vintage 165 hp, 4bbl, auto trans.
Old Apr 20, 2017 | 06:17 AM
zim64's Avatar
zim64
Thanks guys, I will ask him what the year of the block casting is as well.
To odd block stamping, any help?
