Speedo gear and window switches
Old Apr 18, 2017 | 06:12 PM
Grumpy 427's Avatar
Grumpy 427
Default Speedo gear and window switches
I have done a google search to find a link back to this site. lol the search here does not work for me?
Any way i just want a confirmation. I have also used the TCI calculator too. But nothing like real data from real people who have tried a part and got a real result.
80 vette Th-350 trans, swapping 3.08 gears for 3.55. Rear tire is a 295/50/15 book said 26.8" actual measured size 26" i have an 8 tooth on the shaft, so i would need a driven gear with 22 teeth which would be the black or grey depending where you buy it from. Is this the correct tooth count to make speedo accurate.
Does the bullet speedo gear housing ever wear enough to cause a leak, or will changing the O ring seal be sufficient.
Lastly i bought window switches 8 years ago when i built the car, and they were both china crap from Ecklers. They stick in the down position, you have to manually move then back to the middle. Is anyone supplying a better quality sw? or is it all the same china crap.
Old Apr 19, 2017 | 03:08 PM
Grumpy 427's Avatar
Grumpy 427
Wow not one person has switched out power window switches or rear gears and speedo gears. LOL
Old Apr 19, 2017 | 03:30 PM
Peterbuilt's Avatar
Peterbuilt
Step by step repair 'how to' at willcox.
It's worth a look and fixes your original switch.
As for the gears:
Old Apr 19, 2017 | 03:35 PM
Grumpy 427's Avatar
Grumpy 427
HAHAHAHAHAHA...^^^^^^^^^^^^. Did you stay at a holiday inn express last night
Old Apr 21, 2017 | 01:52 PM
Peterbuilt's Avatar
Peterbuilt
Hi again,
Here is the youtube from Willcox on repairing the switch.
Old Apr 21, 2017 | 02:17 PM
Grumpy 427's Avatar
Grumpy 427
I ordered 2 new ones. Tom told me they are hit and miss. HAHAHA great products. Anyway will see what happens when i get them.My factory originals are long gone. Thanks for the video.
Old Apr 23, 2017 | 11:42 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
As for the gears:
To Speedo gear and window switches
