1981 return gas line
Old Apr 26, 2017 | 09:03 AM
svetter84's Avatar
svetter84
Default 1981 return gas line
I have an 81 and the carb had already been converted from electronic when I bought it. It did have a Rochester on it. I have since rebuilt the engine and change everything and now have a holley 670 street avenger on it. On the old carb it had a gas return line on the back of the carb that went back to the gas tank. Now that I don't need it with the holley should I cap it or just put a little air breather plug of some kind? I only have about 400 miles on the new build and I had it plugged but notice a lot of suction when I stop to put gas and unscrewed gas cap. Didn't happen before. It's also not affecting anything with the engine or carb. Just curious what other have done? Thanks!
Old Apr 26, 2017 | 09:16 AM
Dynra Rockets's Avatar
Dynra Rockets
Cap it.
Your 81 should have a vented gas cap on it. Due to age the vent may be plugged. Try a replacement gas cap.
Old Apr 26, 2017 | 10:10 AM
Street Rat's Avatar
Street Rat
I drilled a hole in the underside of the cap on my '81. I'm pretty sure it's a non-vented cap on the '81. Cap the return line if your not using it.
Old Apr 26, 2017 | 10:49 AM
svetter84's Avatar
svetter84
I know the gas cap is an aftermarket locking cap. Thanks for the replies I'll just cap it and get a new gas cap for it!
Old Apr 26, 2017 | 06:03 PM
terry82's Avatar
terry82
i got a name brand gas cap from wallmart .worked fine
To 1981 return gas line
