torque converter dry start
Old Apr 29, 2017 | 12:07 PM
Jayday487's Avatar
Jayday487
2nd Gear
Default torque converter dry start
Okay so i potentially have a problem here, i recently installed a new 4l60e trans in my truck. (this is the first time I've ever done anything like this) when i transferred the torque converter to the other trans i drained most of the old fluid but did not re fill it before installing back on the new trans. at the time i assumed it would be fine and the fresh oil in the pan would circulate and fill the converter. i have heard its super bad to dry start a torque converter so I've held off starting the truck up until i figure out what i should do.
what should i do? any help would be really appreciated!
thanks
Old Apr 29, 2017 | 12:17 PM
'75's Avatar
'75
It's not totally dry, you cant drain it all that way. You should be ok.
Old Apr 29, 2017 | 12:30 PM
TimAT's Avatar
TimAT
you'll never get all the fluid out of the convertor short of cutting it in half.
To torque converter dry start
