Drivers side headlight
Old May 7, 2017 | 01:51 PM
swag's Avatar
swag
Default Drivers side headlight
I have a problem with the drivers side headlight not going up when I turn on the lights. I can manually help it up by reaching under the grill.
It does close when I turn off the lights.
The right side works fine and the left side used to work.
Looking at willcox's vacuum diagram it looks like I would have problems up to the Actuator and after that. I checked the hoses to the Actuator and they look good.
So, does this mean I need to replace the Actuator or is there something else I need to check?
Thanks!
Old May 8, 2017 | 12:46 AM
Antz81's Avatar
Antz81
the seal on the front of the actuator probably needs replacing.
Old May 8, 2017 | 09:54 PM
swag's Avatar
swag
Thanks, you are correct. I reached under the car and the rubber boot that covers it was brittle and broken off.
I checked the right and it was the same so maybe just have been lucky with that one.
Also, the springs were really rusted so I got all the parts coming and will repair the existing Actuators.
Thank you
To Drivers side headlight
