Oil Filter
Old May 16, 2017 | 09:38 AM
upnorth's Avatar
upnorth
Default Oil Filter
1976 350 . When you go to a heavier oil 15x 40 , is there any benefit in what brand filter you use .
Old May 16, 2017 | 09:54 AM
MISTERZ06's Avatar
MISTERZ06
In My Opinion "NO"
for years i used 20W/50 oil in all my engines with A/C Delco, Wix, K-Mart Oil Filters and saw No-Difference
But mu choices for oil filters would be
#1-WIX
#2-AC Delco
........................................ ......... tom
Old May 16, 2017 | 10:37 AM
gbvette62's Avatar
gbvette62
No reason to change the filter. In the 70's, Chevrolet recommended using different grades oil, anywhere from 5W-20 up to 20W-50, depending on the expected air temperatures the car would be operating in. The recommended filter with all grades was the AC Delco PF-25, or equivalent.
Old May 16, 2017 | 05:42 PM
L-46man's Avatar
L-46man
Weeeelll....not all filters are created equal. Some companies advertise this or that micron filtering...meh!
The most significant is an 'anti-drainback control valve'. The cheaper filters do not have this.
So, what does this do?...it keeps the oil in the galleries longer (not forever) after shut-down, so on restart the oil P comes up quicker.
I still use FRAM Toughgards for this reason.
Old Jan 25, 2018 | 06:54 PM
demon340's Avatar
demon340
Another **** thing to do if you plan on keeping your car for 10 to 20 years or longer is changing the trans fluid after the first 500 or 1,000 miles. Most of the crud floating in your trans oil is from the machining and case of the trans when new.
Old Jan 25, 2018 | 08:33 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I use any decent brand and don't worry about it because I change the filter 1/2 way between oil changes (@ 2000 miles of usage) and add a quart of oil. The oil shows minimal wear by the time the 4,000 oil change rolls around.
But I have a daily driver.
Old Jan 25, 2018 | 08:49 PM
00Nassau's Avatar
00Nassau
St. Jude Donor '11
I use AC Delco oil filters in all of my Corvettes. They are reasonably prices, and I have never had a problem with one in hundreds of thousands of miles. Close to half a million miles.
Old Jan 26, 2018 | 11:00 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
In my experience changing oil filters for 45+ years, regardless of what I've owned, I normally buy the cheapest one on the shelf which is probably a Fram or rebranded Fram. Never had a problem.
Old Jan 26, 2018 | 11:29 AM
cv67's Avatar
cv67
St. Jude Donor '05
dd gets the cheapest oil in the store and a wix filter 180k and just fine
a higher dollar motor may spend a little more for good oil but going thick now dont see any gain for you just makes the oil pump work a little harder
To Oil Filter
