Replacing radiator, any tips?
Old May 27, 2017 | 09:30 PM
Andredechimpansee's Avatar
Andredechimpansee
You mean this? Does not tell me how to remove it nor the difference with other years/options.
Old May 27, 2017 | 09:32 PM
caskiguy's Avatar
caskiguy
I guess you missed my point completely. So do it your way and that's Ok.
Enjoy the weekend.
Old May 27, 2017 | 09:39 PM
Andredechimpansee
English is my 4th language. That might be the rason I missed your point. Still do, so please explain your point. Also is the picture what you refered to earlier?
thx
Old Sep 10, 2017 | 12:49 PM
Andredechimpansee
Default Ra
radiator is out!
But can't remove the transmission cooler line fittings...wd40 nor blowtorch helped...
Any tips?
Didn't find them online.
Old Sep 10, 2017 | 02:46 PM
bradleyb66's Avatar
bradleyb66
Originally Posted by Andredechimpansee
radiator is out!
Any tips?
For the transmission cooler lines coming out of the radiator, just do a google search for '79 corvette transmission cooler lines'. I'm sure most of the vendors carry them - here's the Ecklers page: http://www.ecklerscorvette.com/trans...ing-lines.html
Old Sep 11, 2017 | 02:57 PM
540 vette's Avatar
540 vette
It took you 4 months to get the radiator out.
Old Sep 11, 2017 | 07:26 PM
C3 4ME's Avatar
C3 4ME
well, I hadn't thought about you having an auto with trans cooler lines. My 79 is a manual so I don't have that problem. you should have been able to just lift the shroud out now, with the radiator out, correct? Did you get the fan wire harness disconnected?
Old Sep 12, 2017 | 08:29 AM
Street Rat's Avatar
Street Rat
Originally Posted by C3 4ME
Yup, that shroud aint comin' out until the radiator is out! You can just unplug the wire connector for the electric fan on the passenger side fender well.
Remove radiator first. Preferably with two people. Or take the hood off and you can easily do it yourself.
Remove shroud and electric fan. The connector is on the right side inner fender down low. Trace the wires back from the fan.
