Recentering Steering Wheel
Old May 16, 2017 | 01:28 PM
loquinho's Avatar
loquinho
Default Recentering Steering Wheel
I installed a Borgeson Box over the winter, and since I aligned the set screw on the rag joint with the flat on the steering column (correct method for stock steering, but the instructions tell you if you do that your wheel might be off), lo and behold, the steering wheel is almost 90° off center.
I could take apart the rag joint connection (for the third time) and file a new flat for the correct orientation, but I was hoping there was some way to redo it at the wheel instead.
So far I've removed the horn assembly and wheel and am down to the hub (straight column, no tilt-turn). From the diagrams I'm seeing, it appears the hub is attached to the column with a friction-fit spline connection same as the rag joint. Can I remove the hub, spin it to "straight", and reattach it to get everything set correctly, or is there some reason I can't or shouldn't do that?
It's hard to feel the satisfaction of redoing the steering when I'm staring at a sideways wheel the whole time I'm driving.
Old May 16, 2017 | 01:38 PM
Mr D.'s Avatar
Mr D.
Do you have a Service Manual and/or Assembly Manual, should say in the how to align the steering column and Rag Joint.
Should be no reason to take the Rag Joint apart.
Old May 16, 2017 | 04:30 PM
MaynardZed's Avatar
MaynardZed
Just bought a '70 fixer upper and the crooked steering wheel was one of the first things I fixed. Mine is the tilt version and was about 60 degrees out of place. I just removed the 6 screws holding it in place and moved it 60 degrees to make it straight.
Old May 16, 2017 | 05:11 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you need to verify the hub is installed correctly (orientation) to the steering shaft.
Old May 16, 2017 | 08:41 PM
'75's Avatar
'75
If the hub is not installed to the shaft correctly, the turn signal cancelling cam won't work right. With the Borgeson set up, the upper rag joint flange to the lower steering shaft spline is the place to correct it.
Old May 17, 2017 | 03:39 PM
David Mc's Avatar
David Mc
I agree with '75. It's really not that time consuming to correct.
Old May 17, 2017 | 06:02 PM
loquinho's Avatar
loquinho
Ah well. It just seemed so much easier to fix the problem while sitting in the drivers seat rather than leaning over the front fender. No worries. Thanks for the help guys!
Old May 19, 2017 | 08:02 AM
CraigH's Avatar
CraigH
I found it easier to just pull the column back and file it as outlined in the Borgeson instructions.
Then it is all aligned perfectly.
Old May 19, 2017 | 02:39 PM
loquinho's Avatar
loquinho
Could you clarify on that? Are you referring to collapsing the column further or disconnecting the column entirely from the body?
Old May 19, 2017 | 05:07 PM
CraigH's Avatar
CraigH
No the column was already collapsed.
I just pulled the column out of the rag joint and ground/filed a flat spot on the spline to allow the locking bolt to seat at the new location.
To Recentering Steering Wheel
