What would the signs be ?
Old May 20, 2017 | 09:02 AM
upnorth's Avatar
upnorth
Default What would the signs be ?
Getting ready to install new intake . I just put a new carb on last year Quick Fuel HR 680 VS. The new intake suggests 650 to 800 carb . What do I look for if its not enough carb?
Old May 20, 2017 | 11:19 AM
MISTERZ06's Avatar
MISTERZ06
........................................ .......... tom
http://www.csgnetwork.com/cfmcalc.html
http://www.ehow.com/how_7570346_calc...retor-cfm.html
http://www.hotrod.com/articles/how-b...b-do-you-need/
http://www.hotrod.com/articles/selecting-right-carb/
Old May 20, 2017 | 01:36 PM
upnorth's Avatar
upnorth
Put the same numbers in each
355 at 6000
1 616
2 770
3 524
4 said you can't use a standard formula .
At least my 680 is somewhere in the middle .
Old May 20, 2017 | 02:38 PM
Procrastination Racing's Avatar
Unless you have a wild cam and heads and a motor built to race, you will rarely need more than 650 cfm on a small block. More people over-carb than under-carb.
The way you will know is if it falls on its face before reaching top end.
Old May 20, 2017 | 08:40 PM
sunflower 1972's Avatar
sunflower 1972
I believe the stock Rochester 4 bbl carb was 750 cfm, which is a spread bore design. IMHO, what you have now should be fine.
To What would the signs be ?
