New tach cable install?
Old May 22, 2017 | 09:17 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
Default New tach cable install?
I need to put in a new tach cable. I could use some directions and any in-sight from anyone with this experience.
Old May 23, 2017 | 06:57 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Are you replacing the cable/schroud assembly or just the cable? If just the cable it can be purchased from local parts house. It is same as speedo cable just shorter. The cable kit should come with instructions as to how to shorten [as it is a universal kit and comes quit long] and special crimper to attach end. Make sure schroud is clean inside [brake clean] and no kinks, lube new cable with graphite lube. Spin by hand after install into schroud to make sure there is no binding. Removing cable from schroud, it only comes out 1 way I think from tach end, but needs to be disconnected at both ends for reassembly. Tail lites on your advatar are after 73 and in 74 GM went to HEI with electric tachs, so what I described is for pre 74. T
Old May 23, 2017 | 09:30 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
#1 orientate the dist. so you have a straight shot with the tach cable,
and not bending the line. it will run smoother and not fail.
Old May 23, 2017 | 08:30 PM
jbaron's Avatar
jbaron
Thanks guys
Old May 24, 2017 | 01:40 AM
Z06LMB's Avatar
Z06LMB
Man, you guys are sharp, seriously though - good catch on the tail lights!
Old May 24, 2017 | 06:55 AM
1LE's Avatar
1LE
75 was the first year for HEI, not 74
Old May 24, 2017 | 01:05 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Most of the online corvette shops also sell 90 degree adapters for the speedo / tach cables so you can avoid really tight bends. I think they're like $50-$75 if I remember correctly, so not cheap, but an option.
Adam
To New tach cable install?
