battery drain issues
Old May 26, 2017 | 07:53 PM
Titosvette78's Avatar
Titosvette78
Cruising
Default battery drain issues
I've own a 78 vette in good shape (body and paint) just drop a new engine and it drove and feels amazing. i decided to send it to a shop to get rewired, because none of my gauges where lighting up. when i got the car back i got the transmission rebuilt and the car would drive amazing, but if i didn't drive the car for a day the battery would be completely drained. after that i got the alternator tested and a new battery and the alternator was good. i replaced all the fuses hoping that it will fix the issue but no luck. so decided to take the car out for a couple of meets, and i drove the car all day hoping that the battery wouldn't drain over night and surely it did . so i removed the side panels where the shifter sits and all the wires look new. any idea what the issues could be? any advice would be helpful
Old May 26, 2017 | 08:36 PM
SwampeastMike's Avatar
SwampeastMike
The alarm system is a VERY common cause. Remove the connector on the relay just ahead of the shifter on the driver side.
Old May 26, 2017 | 09:26 PM
LS4 PILOT's Avatar
LS4 PILOT
to drain over night , you got a pretty good leak going on for sure. Any of the alarm switches, light switches . I suppose that hated light contol box under the passenger dash might short itself internally . Dome delay whatever ...i hated that thing.
get an amp clamp see if you can find the guilty circuit.
you can take one fuse out to a circuit and see if that stops the drain , locate the circuit and then fix the issue.
amp meter is probably easier .
Radios are also know to have defects .
one issue with old cars is the column KEY switch .....they can wear and when you turn the car off ....the key actually can be pulled out with the electrical contact still on giving power to the circuit . When the key is pulled out , but power is still available to circuits . my keyswitch was worn so much on my Camaro , it released the key without the key in the full off postion. It was tricky to find this this.
Old May 27, 2017 | 10:21 AM
raydog9379's Avatar
raydog9379
Check the courtesy timer as the above poster talks about. Follow the instructions for checking battery drain that include courtesy timer. You'll prob. find it pretty easy when searching. Just make sure the door is closed when you check so that the "timer" goes off after a min.
I went through everything like many here and that was my issue. I couldn't park anywhere for over a couple hours without disconnecting the neg. terminal...or risk being stuck there. I lived with it for over 10 years.
Once I determined that was my issue, $30 board replacement from Willcox fixed the issue in about 5 minutes or less. It's behind the glove box liner in an orange box. Wish I took care of it sooner, but probably the easiest C3 fix. I now can leave my car overnight, park, heck not drive it for a week or 2, and am all good. I probably have another small drain somewhere as it'll eventually drain... so I'll tackle that at some point.
Old May 27, 2017 | 11:13 AM
Peterbuilt's Avatar
Peterbuilt
At the starter, there is a BLACK wire that should be connected to a bell housing bolt.
It is a ground for the wiper motor and fan and might be connected to the top big lug on the solenoid by mistake.
If that is not the problem then see post 1 here.
https://www.corvetteforum.com/forums...with-pics.html
Old May 27, 2017 | 11:15 AM
Tooonz's Avatar
Tooonz
You mentioned you just dropped a new engine in, A common mistake, one I did as well was when connecting the starter. There is a black ground wire that looks like it should fit on the positive terminal of the starter, but in fact it is supposed to ground out to the block and transmission. Check to see if somehow you connected it to the positive terminal ( the fat terminal ) on the starter, that will drain your battery over night. ask me how I know. ( Sorry while I was typing I didn't see the same info posted above )
Old May 27, 2017 | 04:37 PM
SwampeastMike
Titosvette:
I got notice of a reply from you saying that you'd already disconnected the alarm relay vut don't see it here now. ???
If you haven't found the problem already but before you begin the "remove all fuses--replace one-by-one checking for current draw with test light/ammeter thing" I suggest removing the CTSY fuse to see if it stops the problem. From the experience of my '79 and paying attention to this forum for a few years I am very confident in saying that is the most common-by far--circuit responsible for battery drainage.
Old May 28, 2017 | 12:23 AM
Titosvette78
Cruising
Default Updated
So after testing each fuse with a circuit tester I found out that the clock fuse was the one draining my batter.
Old May 28, 2017 | 12:36 AM
Peterbuilt's Avatar
Peterbuilt
Default Good job troubleshooting!
The clock fuse also powers up the Courtesy Light Delay so that may be the problem.
Remove the orange CLD and connect the two WHITE wires together.
Your courtesy lights will now go ON and OFF as you open and close the doors lights.
Old May 28, 2017 | 06:57 AM
SwampeastMike
That's the CTSY (courtesy) fuse. Do you have a power antenna?
Old May 30, 2017 | 03:57 PM
Titosvette78
Cruising
sorry i took so long to reply i was out of town, and yes i do. after i got back i notice that my dash lights don't turn on anymore and i know its cause i removed the fuse and I don't know much about electrical stuff when it comes to cars.
To battery drain issues
